I have a blogpost in that category, and also tried putting in the post-id but it still doesn’t pull up.
https://prnt.sc/zXmzbu25jklO
https://prnt.sc/rZTbkKIDpmK-
post.php?post=1855 <- that post id in the screenshot is 1855.
You can’t use two filters at the same time; you can use a post ID or filter category.
You can customize the category template. For the category template, please use a posts loop; if you have set a posts loop, it will display all posts in this category. Alternatively, you can use Flex Block/Big Grid Flex and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png. This is why the block will display posts for each category.
