Flex Block Pagination Issues
Pagination no longer works with Flex Blocks since the update. We have attempted to switch to different types of flex blocks and use different modes of pagination (load more, pages, infinite load). The block simply shows infinite load icon. We have no issues with flex and post loops.
We have attempted to create new flex blocks and change the flex box types with no luck.
The plugins have been updated to the most recent versions. We are considering rolling back the update to see if that will address the issues.
Do you have a suggestion on next steps?
Update: We have narrowed the issue to Flex Block 1. The issue continued to occur when we rolled the theme back. Flex Block 5 is working before and after the update. We have not tested whether 2-4 is working or not. We will use Flex Block 5 in the mean time. We have no idea why Flex Block 1 is misbehaving.
Strange! I’ve tested Flex Block 1 with all pagination types, and it’s working well.
Are you sure that you have multiple articles? Also, check the console while this issue appears to see if there are any errors.
