Flex block stort order not working
Site: https://gazetapetersburska.org/
I use flex blocks with sort order: latest posts and it seems to work in quite random way – not showing latest posts but starting form 3rd or 4th. I see this issue no matter if I am using Category filter or not. Can you help me please?
Please check if you don’t have set an offset on the block settings and let the offset field empty with no space, no value => https://i.imgur.com/WHvPdtz.png and see the results.
