Hello !
Please note that all the PRO demos and the library templates are fully editable using tagDiv Composer, in order to change the background color / image you will have to edit all the ROWS as you can see here: https://www.screencast.com/t/QlYxvmdoUxea
The yellow background color is set on this demo using a class set in theme panel -> if you remove that class there will be some elements that will no longer have the extra code set on that class that is overwriting the composer settings.
Hope this will help you!
There’s no such color in Theme panel. Found that it’s written in the file:
wp-content/plugins/td-composer/legacy/Newspaper/includes/demos/history_pro/demo_style.css but changed there doesn’t change it on the web, as web loads wp-content/plugins/td-composer/legacy/Newspaper/includes/demos/history_pro/demo_style.css?ver=10.3.6.1
How to fix it?
