is it possible to specify a different number of posts to be shown in a block depending on the device? There are different device tabs on the general settings for the block, but when I change the number of posts, this change is applied across all devices.
Klaus
Flex blocks can do that, this option is per device – http://prntscr.com/n9ktou So with these blocks you can have for example 3 posts on desktop, and one on mobile.
The limit setting is not per device at the moment – http://prntscr.com/n9kuqr
Thanks, that’s what I though. Would be a great feature for the future in order to be able to show more posts on desktop (regardless of number of modules per row) and less on mobile.
@Voogia Changes it how exactly? We are making tests with the plugin to try and provide a better compatibility between it and the theme.
In some cases I have seen before, there could be issues if comments are enabled for pages in the theme panel, please try to disable them if possible – http://prntscr.com/oh4ghx
Also there could be a problem if you disable the comments for specific posts.
Hi Voogia,
Please send us an email at contact@tagdiv.com with your log-in information so we can take a closer look at your set up configuration page. Also, provide there the link of this topic so we can quickly identify you.
