Flex blocks for current category
Is it possible on a custom Cloud Library template to make a flex block layout grab the current category’s posts?
Without needing to make a different layout for each category.
For this you can use a category template from tagDiv Cloud Library, these can be edited with tagDiv Composer, the flex blocks can not achieve what you need, but the posts loop elements can, these can be set in pages and templates and will show related post from that category, archive etc.
