Flex box – sort by worst review scores
Hi there,
Is it possible to sort flex boxes by worst review scores rather than best? I assume this will require some custom coding, but which files do we need to look at?
You can find the code for flex blocks here:
1. To add an option for sort that appears in td composer, you need to go to td-composer/legacy/Newspaper/includes/td_config.php, starting with 39233 line (get_map_filter_array function)
2. To add the functionality for the new function, you need to go to td-composer/legacy/common/wp_booster/td_data_source.php and edit the shortcode_to_args function
Hope that helps you!
