I have another question about the Flex Loop Builder/Flex Loop Filter.
The tool is perfect for our job requirements to show companies and events.
But! At one point user-unfriendly. Or illogical.
https://www.bankingclub.de/wp-content/uploads/2025/01/02-01-_2025_15-31-06.png
With the two filters I can filter the entries – as the name says – and I get the result directly in the list.
If I click on the taxonomies, as a user I think I’m doing the same as with the filter. But I end up on an archive page.
Is there a trick I am overlooking?
– Either clicking on a taxonomy does the same thing as the filter
– Or, you would have to switch off the link on the taxonomy
Translated with DeepL.com (free version)
Another question, same Filter:
https://www.bankingclub.de/wp-content/uploads/2025/01/Screenshot-2025-01-02-202723.png
The text in the buttons is not visible. I have tried a lot but cannot find the settings for this inner area of the button
If you use multiple filters, then you should use the Multi option: https://app.screencast.com/PxbRwrAyvcmxG
Check the settings of your filters: https://app.screencast.com/0mKoXd53qcIh2
You can display them vertically or control their width.
Multi option is set! But is this the answer to my first question?
Topic “filter settings” I mean the text inside of the filter
https://www.bankingclub.de/wp-content/uploads/2025/01/sshot-2.png
Apply these settings here: https://app.screencast.com/0mKoXd53qcIh2, and text should be displayed well there, too.
If you can’t handle to arrange them, then please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
I’ll help you!
