Flex Loop Builder Pagination Issue
Hi there,
I’m having an issue with the Flex Loop Builder pagination. With this element, I’m listing a few custom post types, using a custom module template for them, and I’ve set the pagination type to “Normal Numbered” to list the posts across multiple pages.
So far, pagination has been working fine, but today I’ve noticed that it no longer displays the numbers at the bottom, or sometimes displays fewer pages, even though there are multiple pages available.
For instance, this Flex Loop Builder contains 11 pages of posts and, being on the 4th page, it displays them correctly:
https://prnt.sc/nPcbfUmme8Rw
On the 3rd page though, only 6 pages are listed, and the rest are missing:
https://prnt.sc/jnmttp3nbRjV
This sometimes happens on any other number – fewer pages are listed when there are more posts on the following pages, or the pagination disappears completely.
I would really appreciate your support in this regard!
Can you please provide a link to the page were the flex loop builder is used and you are facing this problem? It will be need to investigate the problem.
Hi Calin,
Thank you for your reply!
Here is an example page you can check to see the issue:
https://okanaganfamilyfun.com/location/penticton/
For reference, there should be 11 pages of posts available in total.
However, on any other “Location” page you navigate to, you will be able to see the problem appearing.
Please navigate to different pagination numbers as the issue doesn’t always appear on the second / next page you access.
The problem seems to be the lightspeed cache that is apply on pagination. ON paginations that are not cached are displaying the right numbers of pages and articles. You need to exclude from cache this parameter ?tdb-loop-page
Oh, I see…
Thank you for your support, Calin!
I’ll do so and see if that solves the problem.
Thanks again!
  • This reply was modified 1 year by mottoyou.
