Flex Loop Filters and Flex Loop Sorting Options
(Using the latest version)
– Flex Loop Filters: Is there anyway to make it load results in ajax?
a. The filtered field are hidden when selecting an option. (any options)
b. The page keep reloading at each selection
– Flex Loop Sorting Options: This is returning results in ajax. Why not the above?
a. There’s only 3 options: Oldest posts, Modified date, Alphabetical A -> Z
b. How can we had options? Real Estate standards have (price asc/desc), size (asc/desc), year built.
Thank you
Hello @obiwan !
No. There is no option.
a. Can you please provide a screenshot with what exactly do you mean?
b. This is the way that element is working.
Because it was implemented that way.
a. Yes.
b. Please provide a screenshot. From what I know, there are no other sorting options.
Hello Bettina,
https://prnt.sc/CqHxcQgNvtf-
Once we select an option all filters disappear.
https://prnt.sc/BhzBlV6bCtcU
https://prnt.sc/zXeMhv2b80Rm
We need to add filters to these options
Thank you
Hello @obiwan !
a. Please apply the Multi option: https://prnt.sc/xPsILrwoscji
b. Unfortunately, we do not have any other filter options. In order to add any other option for filtering, you will need custom work.
For customization and other services, you can contact our custom work team here: https://tagdiv.com/premium-customization-services/.
Thank you for understanding!
Hello Bettina,
They already are.
It feel more like “buggy” to be honest. While other modules work smoothly this one is kind of… meh.. :/
Thank you
Hello @obiwan !
Make sure you’ve cleared all the cache when you try that again.
Hello Bettina,
Still no improvement.
Thank you
Hello @obiwan !
The multi option is working as it should in the latest update of the theme.
After you choose the first dropdown, wait until it refreshes, and then apply the second dropdown.
Hello Bettina,
Could an update not to refresh the page after each selection be implemented in future releases please?
This is by far one of the most frustrating thing about the theme. :/
Thank you
Hello @obiwan !
I know. But this is the way the feature has been implemented in our theme.
We’re sorry for this inconvenience!
