Flexbox 1 – Latest Posts/Articles Filter not working
I am encountering an issue using the Flexbox 1 element on the homepage of our website (thefootballweek.org), under the “World Voices” section.
I have a category which I want Flex Box 1 to display the latest articles for, I am able to load the category, but I am unable to load the latest articles.
Strangely, I can see it working in the TagDiv editor, but when I click save, it stops working on the published page, meaning that there is an issue occurring between the editor and display of the page.
Please see the attached screenshots for further context: https://imgur.com/a/84FUWYw
I have updated the theme, and I have also ensured that there is 0 offset value so it shouldn’t skip any posts.
If you could please advise.
Many thanks
You need to let the empty the value for offset, so please delete the 0 from there.
Thanks for getting back – there is no offset value, see the screenshot below:
View post on imgur.com
HI,
What cache plugin do you use? Also, do you have the cache option enabled on the blocks https://i.imgur.com/WkFwOWI.png?
No caching app is being used, and the cache option isn’t enabled on the blocks. I do use the auto-optimiser that the theme recommends using – could that be causing interference?
I would like to take a look. Can you please email us at contact@tagdiv.com with the wp-admin and cPanel access and include the link to the topic in the email?
