Hi!
We have the problem with the flexbox ajax subcategories selector. Basically in the subcategories the latest post are correctly shown, but in “All”, the posts that are shown are not the latest.
I captured my screen to explain the problem more clearly you can see the video here:
https://youtu.be/-G3LuQIOeHg
We need response to this as soon as possible.
Thank You
In our demo we are using the Unique articles option on the homepage in this way the articles will be display only once, therefore this article from Travel category is not the last one, the last one from that category is displaying in the above grid -> https://i.imgur.com/ojkPumP.jpg -> https://i.imgur.com/L1ysX3F.jpg
I think that is the same on your website, you have the unique articles enable -> https://i.imgur.com/l8hgwqW.jpg please disable the option and check gain.
Hope this will help you!
Have a happy Easter!
Hi Calin!
Thank You for your answer. I’ve checked it and we don’t have Unique Articles enabled. In fact I Enabled it and Disabled it again to see if it changes anything but no, we still have the same problem.
Is there any other possible solution?
Hi again,
We solved it and was a super obvious problem: my colleague set “offset posts”, and we forgot about it, and as it was mega obvious we didn’t check it until now…
Now we have an other doubt:
– The first block on our page shows posts from a specific category (let’s call it “Highlights”).
– For the second block (Actualidades) we’ve set to exclude this category “Highlights”. But some posts of “Highlights” are repeating in “Actualidades” but only in the ajax subcategories. This problem happens even with “Unique Articles” turned on.
To show a similar example from your demo:
The article “15 Grooming Techniques Every Man Needs to Know” appears in the first block. Later in the second block doesnt appear on the front (Dont Miss / All) but appears on the ajax subcategory “Don-t miss / Travel”
Isn’t it possible to hide it from the ajax subcategories also so it is not repeating at all on the page?
