floating elements outside container not visible
I have an issue with plugins that want to place floating elements outside the content container. They always get overlapped by the theme background. Can I move the theme background below such elements?
See here… http://imgur.com/a/RMqCe
I have noticed this happens only with Google Chrome. You can see it here:
http://winbuzzer.com/2016/09/20/windows-10-redstone-2-update-adds-outlook-calendar-xcxwbn/
I had to deactivate the plugin, but the screenshots explain the issue quite well http://imgur.com/a/RMqCe
HI
When you’re using back-ground color or background image the theme switch in boxed layout and only page’s content is visible. We didn’t made any tests with floating elements and outside td-outer-wrap container but you can try to make a new container in header and display there your floating elements, here is an example: http://screencast.com/t/upKDd8sGc – http://screencast.com/t/ztr6jijjBJi7
