Flow-Flow Plugin
We recently added the plugin Visual Composer – Social Streams With Carousel (http://codecanyon.net/item/visual-composer-social-streams-with-carousel/11471294) to our website. Once activated it causes some errors to the theme:
1. removes back to top button.
2. removes read more pop up module.
3. removes category filters on block’s
Wondering if you had any idea on why this would be. Still waiting on a response from plugin developer.
Thanks,
  • This topic was modified 10 years by drae.
Hello drae,
Unfortunately, these Add-on are not supported by our theme, sorry! Please notice that each our plugin has adjustments in the theme in order to work fine with the theme. If you want to make it working fine on the theme you have to alter the code from core file and do some additional customizations to adjust the theme with the plugin extension that involves custom work. If you want to develop our theme and you want to add some additional options in the theme and you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry! Usually, we recommend the developers from studio.envato.com.
Thank you for the message!
