Font Color Comment Problem
Hi I have a problem with the color of the comments on my posts (articles) … The color is similar to the original background of the theme and I don’t understand how to modify it. I went to the control panel but didn’t understand what the voice was.
I find the same problem in the buddypress galleries, the comments are not read.
How can I solve the problem?
Please provide me a link where I can check these comments in this way I will be able to show how to change the color, or to provide a custom css for this.
Here is the link. As you can see, under “Basic” Profile Group Editing, the name (mandatory) is a color that cannot be read
https://www.stayrock.org/membri-2/spike/profile/edit/group/1/
In order to have access to the link provide I need to login, also I think that you are using some custom code or plugins, if you are referring to this part -> https://i.imgur.com/ivV8FZ6.png please try this custom css -> http://prntscr.com/q25cgi
.buddypress-wrap table.profile-fields tr, .buddypress-wrap table.profile-fields tr p{
color: #000;
The code need to be set in Theme panel> Custom code> Custom css
Ok funziona bene. Il problema è che se vado sulle sottovoci: Modifica ho di nuovo lo stesso problema
Se vado su Attività, i post risultano con un carattere poco visibile
Se vado su impostazioni E-mail dove va inserita la mail, non si legge fin quando non si fa click sopra ecc ecc
Ok it works fine. The problem is that if I go over the subheadings: Edit I have the same problem again
If I go to Activities, the posts are not very visible
If I go to E-mail settings where the e-mail is to be inserted, it is not read until you click on it etc. etc.
Problem in modify: “Name (obbligatorio)” and the mail field Don’t read, and –> profile https://www.stayrock.org/membri-2/spike/profile/edit/group/1/
Problem in activity: The color of the test don’t read –> https://www.stayrock.org/membri-2/spike/activity/
Problem in gallery: the comment at photo don’t read well –> https://www.stayrock.org/membri-2/spike/mediapress/
Problem in Setting profile –> https://www.stayrock.org/membri-2/spike/settings/profile/
So it seems that every tab of the buddypress menu has a problem with the fonts and I don’t know if there are others because at the moment I can’t see notifications, friends and more …
Where can I find the css codes for these settings?
Sorry, but I can not check these links, I need to connect to your website to have access to them:
Also I can not identify the text that can be seen, please provide some screenshots about this problem, in this way will be more easy to check the problem.
If you want, I send the admin login to check the pages with the account. Where can I send you the data?
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
