Font is not responding [https://forum.tagdiv.com/how-to-use-custom-fonts/]
In td_fonts.php, I switched out this line of code:
‘fs_2’ => ‘”Helvetica Neue”, Helvetica, Arial, sans-serif’,
for:
‘fs_2’ => ‘Roboto, “Helvetica Neue”, Helvetica, Arial, sans-serif’,
And when I go to Typography settings in Theme Panel, I can see that the change did in fact work. HOWEVER, when I see it “live” on my website, for some reason, it crosses out my “Roboto” text (as well as “Helvetica Neue”, but it always did this for Helvetica Neue), and goes directly to Helvetica text…
The thing is, Roboto font ALONE works perfectly fine…
Here is the screenshot to clarify what I am saying…
http://s9.postimg.org/junkurfin/wtf.jpg
And yes, I tried this while deactivating EVERY plugin. Results are the same.
  • This topic was modified 12 years by GosuSama.
Check if there’s some css overriding this setup and please provide a link so i can take a look.
Thank you, Emil G.
Hello Emil,
I am not too versed in the technical side of WordPress, and I don’t think I made any changes to any CSS/overriding, so I wouldn’t know where to start. But everything should be “default” as I did not make any customizations to the website other than what I have attempted to do here.
The link is http://www.Leadnr.com
I’ve tested it on an article title and it seems to work fine – http://screencast.com/t/2pr4B38bhttp://screencast.com/t/YWrI4Ny2Yev
Please provide a link to a page on which the issue appears.
Thank you, Emil G.
Hello Emil,
The one you are looking at is set to Roboto, which is why it is working.
However, if you check the Content Font @ http://leadnr.com/video/10-reasons-creating-test-posts-cat
You will see that Roboto is not able to be read. It automatically skips Roboto and goes straight to Helvetica Neue
Replied here!
Hi Lucian,
And thanks for replying. I am now able to change fonts, their sizes and etc; that is the good news. Also, I don’t know what happened, but now the issue with Roboto being crossed out has been fixed!
However, there’s just one thing I need to ask you, because it’s a problem I am having with my Font.
http://s12.postimg.org/48p2mb99n/Screen_Shot_2014_09_19_at_4_12_38_PM.png
As you can see, I have a font on my website using Roboto Condensed… But the thing is, in Typography settings, there’s not a SINGLE font that is set for Roboto Condensed… I don’t know where I can go to change this font to Oswald or any other font…
Any help is appreciated.
Actually, don’t bother reading above, things have changed since then, I will re-post the update. Thanks.
