Font Problem
Hello. I wrote a small “i” in large letters automatically “I” had the letter translated into “I” in turn. Example: Güzellik/GÜZELLIK
http://www.kadinium.com
Hello. I wrote a small “i” in large letters automatically “İ” had the letter translated into “I” in turn. Example: Güzellik/GÜZELLIK
I am not sure what you mean. Please provide more details about this issue so i can inspect it closer, also a screen pointing the issue would be helpful.
I have written in lowercase “güzellik” word (Turkish) some uppercase characters not transforming in the main menu is Turkish.
For example, the “i”
In Turkish, “güzellik” well capitalized the word “GÜZELLİK” should be written in the form of “GÜZELLIK” as written.
[url=http://hizliresim.com/PPqqo5][img]http://i.hizliresim.com/PPqqo5.jpg[/img][/url]
I don not think this is a theme problem but rather a font problem. Please try to use fonts that support Turkish language as exemplified here: http://www.fontsquirrel.com/fonts/list/language/turkish and make sure you enable support from here for google fonts: http://screencast.com/t/WgSho0gJ9Iu
You can add custom fonts like so: https://forum.tagdiv.com/using-custom-fonts/
I hope this helps.
None of the fonts in your font list does not appear on the font list Turkish compatible mate. Adding custom fonts in the section “font link” part I understand, unfortunately.
Thank you
Please provide some screenshots with your font settings so we can take a look and make sure you use fonts that support Turkish language as Bogdan suggested above.
We will get back to you as soon as possible because we do not work this friday nor trough the weekend due to the new year period so we’ll get back in touch with you on monday.
Thanks! Happy new year!
