Font Problem
I am using a custom font for my website.It was working well. Unfortunately, since yesterday the website is displayed with another font in my laptop, not with installed custom font. For others (at least two or three whom I have asked) it works correctly. I have formatted my system, reinstalled browser, used other browsers, deleted cache using Web Super cache etc. But nothing has helped. Will you be able to support to recognize the problem and to sole it?
Hello srampia,
Please try to purge all CDN files if you are using the CDN system and check the results. Also, if the problem is still there, please provide more information about this regard so I can inspect it closer your setup page. Also, you should provide your website URL and so screenshots with your problem.
Hello Catalin,
Thanks a lot for your answer. Unfortunately, I could not purge CDN files. As I try to purge CDN files, I get the reply. ‘Sorry, you do not have access to purge cache for that zone id or that zone id is invalid’.
My website Url is: http://www.lifeday.online/
Hier I have used another font, which is relatevly small.
http://www.screencast.com/t/G5X7lmnU
http://www.screencast.com/t/VwWN8Xr1Ej
Hello srampia,
I have checked your website and I saw that your font are the same on modules and post pages, as you can see here -> http://screencast.com/t/YQZ9a2T8t If you do not have any access to your CDN system you should contact the CDN hosting.
