I set my website but ı have the font problem its not read turksih character.
I added the some text and ı try to chance font style or font type its not fix.
Please can u check it?
How can use this theme (Center Magazine) with turkish character
I made a test and for me works well -> https://i.imgur.com/E5Mmz1u.png
Please provide some screenshots with your settings.
you can see on the link
https://r.resimlink.com/1uR4rH0ysWh.png
https://resimlink.com/hBtrNzaxys
on the website
http://sanatyurdu.com/tag/aytac-manizade/
http://sanatyurdu.com/2022/03/30/isogu-gsi/
Some character is make a problem like ŞÇĞ şÇğĞ
please check it
For me look like this https://i.imgur.com/X25CbTt.png, but please let me know what font family you have set, I have Kanit ->https://i.imgur.com/HMUVPUm.png
i change it like u and its worked before ım try to change it on theme panel/font setting and its not work
so thanks.
