Font problem on Firefox, Safari And Edge but work on Chrome !
Hi, I enabled Google Font on theme and I use “Quicksand” Font ! This font work on all website but except on menu and sub-mega-menu.
We can see the problem (firefox and edge, the police are ugly but not on chrome)
https://ibb.co/dmNdvQB
The adress of this website is : https://www.onibiote.fr
Best regards
Unfortunately, this sohuld be the results from more browsers, sorry -> https://www.screencast.com/t/oY3UaD2Wg8H Here is talking about the browser interpretation of the font which is not a theme related problem, sorry!
Thx, but this problem it’s just with my website (NewsPaper theme). With all other website I no have problem.
https://ibb.co/tCyy3gz
Quicksand font bug just to “Main menu”, it works on the rest of the site :
https://ibb.co/VJBrGNh
Best regards
I have checked your main menu items and the Quicksand seems to be rendered as expected, as you can see here -> https://www.screencast.com/t/ZVsItbLWp I have tested for all of three browsers.
Thx
What I do not understand is that if you test on another site, the quicksand font works well, with all browsers
Best regards
I do not know! The front seems to look similar. Try to add another font and check the results. As you can see the font is correctly rendered and the theme does not have any issue in this case. If a problem exists, notice that one is browser related and not our theme. You can try with a default theme and check the results.
Thanks for oyur understanding!
