1. i would like to set the fonts on the website and the following pages uniformly. Where exactly can I do this? I don’t want to use Google fonts because of the General Data Protection Regulation.
2. my logo on the website is not displayed in the header on my mobile phone. What do I need to change in the settings or do I need to install the mobile theme panel?
https://2024.mawi-westfalen.de/wp-content/uploads/2024/03/Screenshot-2024-03-17-at-17-26-00-Theme-panel-‹-markt-und-wirtschaft-westfalen-—-WordPress.png
3. where can I set the background color for the header area?
https://2024.mawi-westfalen.de/wp-content/uploads/2024/03/Screenshot-2024-03-17-at-17-42-11-Home-markt-und-wirtschaft-westfalen-1.png
Thank you for your support.
Christiane
1. You can upload the font to the theme panel under “custom fonts” by following the instructions at https://forum.tagdiv.com/font-customization/. After doing this, you should typically not experience this problem.
2. You have a cloud template, so you need to make the changes with tagdiv Composer and delete the logo from the theme panel. For mobile please edit with tagDiv Composer, select the viewport on phone, select the header logo and change it => https://i.imgur.com/cR7F0v4.png https://www.youtube.com/watch?v=HXQQygkCCJo -> https://forum.tagdiv.com/add-logo-newspaper/
3. Usually, the color and image are set on the row, so please edit with tagDiv Composer and select the row and go in the tab CSS https://i.imgur.com/UkgqKNM.jpg -> https://forum.tagdiv.com/topic/background-color-of-the-main-menu-be-changed/
