Fonts and mobile-issues
Dear TagDiv Support,
I have 2 main issues with the theme Newspaper 9.
First:
When loading, the font switches for a very short time to another font, which wasn‘t set by me. I use only one font for the whole website (Acumin Pro), but still a serif font pops up just for a sec. Which is very startling, because the whole website kinda makes a slight shift and it is unpleasant for the eye.
Second:
When looking at the Mobile settings on TagDiv Composer everything is fine. But when looking on the Mobile Phone directly, the settings are different, just like the default settings for Mobile.
What is possibly the problem?
Thank you very much
Best Regards
Natalie
1. You are using Custom fonts files, or google fonts, because if you are using google fonts, until your website loads the style from google will be set the default fonts.
You can try to use a custom font ( https://www.screencast.com/t/fEtxO8EVKx ).
2. If you don’t have mobile theme plugin activate, then the content must be like this:
on td composer https://www.screencast.com/t/QSeF71ZT , on mobile: https://www.screencast.com/t/kFJm0N1H1bB
If you have mobile theme enabled, then you need to add in page, at the bottom of it the content for mobile ( https://www.screencast.com/t/eyqyjVNW ).
Thank you for your answer. Unfortunately this doesn’t help me right now. It doesn’t work. If I shrink the window on the computer screen, the Responsive Design works very well, one would have the perfect mobile phone version. Why is this not simply taken over? It would be a tedious task to create an additional mobile version for each page. Isn’t there a command that automatically calculates Responsive on the size of the mobile phone?
May I give you our login so that you can quickly look at these 2 problems? You can write me personally at creation@nucreation.ch, then I would send you the login. I thank you already now for your efforts. Kind regards Natalie
Please provide a link to your website to can make some investigation on your problem.
