Fonts and Speed Booster
I’m using standard fonts with my theme, and the default font was loading for half a second before switching to the fonts I selected. This had me baffled until I deactivated the speed booster plugin and realized that was causing the issue.
I’m wondering if there’s a way we can adjust the plugin so that it loads the selected font first? Thanks.
You could try to change the theme colors to the ones you like directly into the style.css file like this: https://forum.tagdiv.com/topic/about-default-theme-colors/#post-17657 this way just the one that you want will be loaded.
Also please try to re-install the speed booster plugin and check again.
Hope this helps!
Best fix is to manually edit the style.css file and search/replace the default font stacks with the font stacks you want (we did this to use the Gill Sans font stack). You have to do this with each theme update, but it ensures only the desired fonts EVER load.
