Hello
The fonts on my site do not look right. They look all strange and thin
The menu fronts are all skinny. The single post right hand sidebar fonts have gone strangly skinny. Even when selecting H1 header fonts and single post content fonts they don’t come out how they are mean to as per the chareters/font style chosen. Even in the sticky drop down menu at the top the fonts look odd skinny
My other sub site using your theme and the same menu items the font looks just fine.
At first I thought this might have something to do with caching or litespeed plugin. But turning this off or setting it to default makes no changes.
Can I can why is it doing this. It looks stupid and chosen font’s such as the H1 headings dont come out as per chosen font
Okay so I solved the problem.
However, as per my last log. I found that menus will all change to the correct font. Except for the from page……I wont display the Google fonts in the front page menu omly. And when I turn on cloudflare APO once more the drop down menu items dont work and cannot be clicked
Hi mgiannelis, this is because the cloudflare APO is interfering with some javascript or other plugins, maybe you can try to exclude the menu javascript.
Here is a similar topic -> https://community.cloudflare.com/t/apo-issues-on-mobile-and-js-scripts/230770
