Fonts dont Work
Hello, I turned off Google Fonts some time ago, since then my theme only shows other fonts.
When I adjust things with TagDIV everything is correct, as soon as I save and switch to the normal view of the website, it’s the old font again. Only 1 flex block has taken over the whole thing.
I’m getting desperate here. Tested with cache plugin and without. As well as different browsers and also cleared browser cache.
https://www.stoppeltv.de
Please note that if you use cloud templates, then you should choose the font for each element in the tagdiv Composer.
Check this guide: https://forum.tagdiv.com/font-customization/
Yes, I am aware of that, but it is not taken over. It is displayed correctly as long as I am in the editor. As soon as I save and go back to the normal overview, the other font is there again
Make a test and deactivate all plugins except tagDiv ones. Also, if you are using a cache plugin, deactivate it, clear all cache, and try again.
Let me know the results!
