Fonts: Footer Widgets & Footer Menu & Default Font
I have 2 questions. I tried to replace default fonts through Custom Typography, for everything on my site but still seeing ‘PT Sans’,sans-serif on a few locations.
1. How to change font on Footer Widgets & Footer Menu from default ‘PT Sans’,sans-serif to something else?
2. How to change the theme’s default ‘PT Sans’,sans-serif font.
If anyone knows the answers pls share.
Simply edit the style.css file to replace the default fonts. That’s what I did.
Thanks Chris for you quick answer.
I followed your suggestion from another msg and replaced all ‘PT Sans’,sans-serif with ‘Open Sans’.
Most of the site is ok now but on footer I still see ‘PT Sans’,sans-serif from wp_booster\external\bootstrap\td-bootstrap.css
Maybe, I have to touch it too..
Editing the style.css file should change all of then, only if you missed something or if it’s using another font-family. Please send me a link to your site, I need to inspect this so I can provide you a solution.
Don’t forget you may need to change the fonts being loaded by the theme from Google in the functions.php file also, if not already done 🙂
And, double check the style.css by doing a search for “PT” in the text.
  • This reply was modified 12 years by simchris.
