Update: I have changed all the fonts to Lato, but still in the Sidebar, there are other fonts: Open Sans and Serif
I am also seeing Roboto, Open Sans in the main part of the screen
And on the mega menu (photos) still open sans is showing
Where are these fonts coming from and how do I remove them please?
Paul
Hello Paul,
Please read this topic: https://forum.tagdiv.com/topic/do-i-really-need-to-change-all-the-text-fields-for-fonts/#post-177899
Hi Bogdan
I am not very technical, I can only do things with the front end editor really… is this fonts issue not considered important as it appears to have been highlighted in Jan 2016? There seems to be two things here: 1) the fonts needing to be updated singly is not ideal 2) fonts still appearing after all the fonts have been changed.
Correct me if I am wrong, but the more fonts you load, the slower the speed? In a world where WordPress is already heavy, is it not a priority to try to limit unnecessary weight in a theme? Why has this not been addressed? And can you help me fix this please as simply as possible?
Many thanks
Paul
Unfortunately there is no simple way of changing all fonts at once and removing the theme fonts without very technical implementation. There is no simple method as if there was, it would already be implemented into the theme.
Hi Paul,
Please send us an email at contact@tagdiv.com with your credentials (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this topic so we can quickly identify you.
