Fonts Issue
Hello
We are using sitewide Google Fonts – Roboto. It does look well on our computers but not on others’ browsers.
Original, our computers https://pasteboard.co/IVghB6V.png
Other computers, https://pasteboard.co/IVghQw2.jpg
What is the issue?
Please check on incognito mode, also if you are using some cache plugin, make sure that you clear all cache.
If there is still a problem, please provide me a link where I can check the Google Fonts – Roboto.
Hi Calin
I checked it in incognito mode and fonts looks well on my computer. I do not know others. I also tested the site and fonts do load correctly. Here’s the link you can follow. Thanks for the update Calin
site
Hi Calin
It is displayed correctly only on my computer. Our other computers in the office displays it wrong.
The all must show like this
Is look that the font family Roboto can not be load and is loading another form from the broswer -> https://i.imgur.com/P3hA2Ak.png
Make sure that the google fonts from theme panel are enable -> https://i.imgur.com/Q0AGEGO.png and you do not have a plugin conflict, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Hi Calin
Thank you for your help, silly of me, I did not enabled the google fonts in theme panel..Now the issue is fixed
But strangely, before enabling the google fonts, I still can see the roboto loaded even in the incognito mode. Why is that? How our results can be different?
https://pasteboard.co/IVwzpZK.png
Thank you for solving the issue Calin
This can depend on the settings that you have on your browser, maybe there are other factors too, but this is in the most cases.
I’m glad that the problem was solved.
