Hi there
i modified the td_view_custom_fonts.php like you already wrote somewhere. Just added Font 4,5,6… etc but when i want to put a path inside the textfield and i click on save the letters in the field are just vanishing. When i look into the css of the compiled html domain document i see that the template put the old font OFTEN inside it. Even after i kicked the Font out of the backend it still appears.
I hope you can help me there. Domain: http://www.neulich.org
I also hope that i haven’t got to reinstall the theme, because i already put a lot of work inside it, to get css classes working and stuff.
Honest regards
Manni
When using custom fonts, the path you specify for the font file is very important. It needs the absolute path. In order to check if you have the right path added for your font file you need to open a new browser window and enter the path inside the browser. If the path is correct, the browser will download the font to your pc.
Here is an example of a correct file path:
http://screencast.com/t/cZCm6ONSWA This is on my localhost but you should get an idea of how a correct path chloud look like.
Hope this helps.
