Fonts Not changing
I have installed Technology theme on my website, i tried changing fonts, in the theme panel> Theme fonts, i changed all of them to my desired font name, i did the same in the Multipurpose section. Everything changed except the following stays the same(it is in the ERROR 404 page). from where and how can i change that as well?
see the image:
Hello hellonikoloz,
Try to purge all CDN files if you are using the Cloudflare system, clear all the caches and check the results. All the fonts can be managed from Theme Panel -> Theme Fonts. Check this section according to our documentation here -> https://forum.tagdiv.com/font-customization/
