fonts not working
I updated the theme to 10.3 yesterday and after updating the fonts are not showing on the front-end.. When I enter the composer it does show the correct fonts, but after saving and exiting the composer the font changes back.
My website: https://fminside.net/
And another issue after updating to 10.3: the drop down in the menu has stopped working.
I did a fresh install, so manually removed the theme and plugin and after that uploading the theme and plugins directly to the server.
The drop down menu seems to work now -> https://i.imgur.com/HRXANaU.png
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
Thank you!!
