Fonts upload problem
I have a problem with custom fonts? i chose my own font but nothing change in front site?
I follow all setup to add a new fonts under theme panel.
Even i disable all plug-ins, but nothing change
Do you have any idea plz?
tnx
Hello zawayavision,
If you want to use other fonts and its are not loaded in our theme you have to upload the new font. Below I presented the steps that you have to follow if you want to upload a new google font.
Go to Theme panel->Theme fonts like this: http://screencast.com/t/zh29FwQyA First of all, you have to download on the website custom fonts as you like, of course. You can search a lot of this in this link: http://www.1001freefonts.com/ After you have downloaded the font file, please use this online tool to create your own font: http://www.fontsquirrel.com/tools/webfont-generator
After these steps: http://screencast.com/t/p5vrpGyLrD4 you have to find the .woff file and insert it in Theme panel->Theme fonts->Custom fonts file like this: http://screencast.com/t/5AFW5qRKB Now, your fonts are ready to use. You can find it in Theme panel-Theme fonts, like this: http://screencast.com/t/CFnRX3Fh – http://screencast.com/t/Zkm4J24zwjE
If you want to change the fonts in all the theme, unfortunately, our theme does not a simple option to set it for all this and it is necessary to change it manually in theme panel, wherever you want to defend this font, like this: http://screencast.com/t/HkVYzvlff2
For more information about font customization, please consult our documentation here: https://forum.tagdiv.com/using-custom-fonts/
I have tested the adding new custom fonts of my side according to above tutorial and everything seems to work as expected, by default, without untested plugins.
I hope this helps and let us know how it goes!
Thank you for the message!
tnx catalan,
I already in first time do all setups, but nothing works? i upload a customs Arabic fonts .woff in the same folder + insert correct url + insert a name.
wat’s strange is that i create a sub demo wp site : http://www.ppsmaroc.com/demo/
loading fonts from the same folder, with all correct setups in theme panel, and it’s works !!
But in the main wp site : http://www.ppsmaroc.com/ar/
Nothings works ?!!
here is screen-shots of fonts panel and css inspector:
View post on imgur.com
  • This reply was modified 10 years by zawayavision. Reason: add image
Hello zawayavision,
I have checked your screenshots and saw that you are referring to the fonts from your post title and you try to change this from header fonts field. The post title fonts are affected by the settings from Post title field and not from the Header. http://screencast.com/t/IRP3v2Leew
If is not what you mean, please provide more details about your problems so I will be able to provide a more accurate response.
hello,
sorry but that not at all my problem.
The screen-shot was just a show of that every-thing is setting as the tutorials, but the fonts don’t works.
– I upload the fonts as seen in tutorials
– i chose the font for each elements under the panel theme
But always no changes??
tnx
Hello zawayavision,
I have checked your website and saw that you are not fonts loaded. I suspect your problem that might be caused by your wrong path inserted. Please provide a screenshot in that section, where you must insert the path fonts style so I can inspect it closer, here -> http://screencast.com/t/1zHLGR49f4Y -> http://screencast.com/t/btXAgwxE0tlI
