Food Recipes there is no schema or micro data for recipe??
hi i checked and install the demo for my food blog but there is no structured-data for recipe like pic, rating, time, nutrition, video., etc here is test https://search.google.com/structured-data/testing-tool#url=https%3A%2F%2Fdemo.tagdiv.com%2Fnewspaper_recipes%2Ftd-post-frozen-blood-and-sand-cocktail%2F
can you tell me is there update available for recipe or there is compatible plugin available for this ?? thanks
There is no structured data imported by the theme regardless of installed demo. Easiest way to add schema markup would be by a plugin, here are some guides
– https://www.wpsuperstars.net/rich-snippets-schema-plugins-for-wordpress/
– https://kinsta.com/blog/schema-markup-wordpress/
– https://bloggingwizard.com/add-schema-and-rich-snippets-in-wordpress/
– https://torquemag.io/2016/12/schema-markup-wordpress/
Try some free plugins to add recipe schema to your articles, should be no problem in the matter. The theme will add basic and required structured data, for additional elements plugins can be used.
thanks for reply i try but mostly are paid plugins , free plugins have some errors in markup not fully details markup , wel will you add this feature in future list update ?? the recipe related theme full markup with schema ?
I don’t think this is planned to do unfortunately. You could try other plugins, maybe even manual markup for the recipe data
– https://schema.org/Recipe
Surely one of the existing plugins will work as needed
– https://colorlib.com/wp/wordpress-recipe-plugins/
