Footer – Default PRO not able to edit
Hi I have imported Default PRO demo one my site.
Following issues I am facing.
1.I am not able to edit Footer – Default PRO template using tagDIV composer.
2. Footer section on site is not displaying correctly except home page https://www.attingal.in/category/education/coaching-centers/
3 let me know which Single Post Template using for Default PRO demo
Greatly appreciated your quick support
Hello !
Default pro uses the Single post Default pro: https://www.screencast.com/t/om5aTOkV3i
By using the website manager you will be able to select your footer and edit it as you can see here: https://www.screencast.com/t/FIy3J3wUZErA
Hi Thanks for your reply.
I already downloaded the footer template but I am not able to edit in WP-Admin- Cloud Template section all other template except footer template I can see Edit template | Edit | Trash | View | Duplicate.
on footer template i can see only Edit | Trash | View | Duplicate when i click edit its showing junk characters.
How I can change the footer bg image?
i didn’t get reply on my previous 2 question
“Footer section on site is not displaying correctly except home page https://www.attingal.in/category/education/coaching-centers/ (i tested Firefox, Chrome browsers both are showing same) ”
Hope you understand my concern
Hello !
By using the website manager you will be able to select your footer and edit it as you can see here: https://www.screencast.com/t/FIy3J3wUZErA Select the footer and scroll to the bottom of your page, you will be able to see and edit it.
