Footer delayed load potential issue
In VERSION: 12.6.3
Header block text color overwritten by default color
To replicate issue:
1. Add Header logo block in both – header and footer
2. Go to Style > Text color > make it #fff or any other color on both – header and footer
3. Enable Footer delayed load in theme panel
4. Go on front end – the header logo will initially load in #fff color, but will then change to #222.
This happens because Header block placed in footer first loads default #222, which overwrites #fff specified in Header logo placed in header.
This is likely happening to any element when it is used in header or body plus in delayed footer.
The issue is caused by the inline css option, not the delayed load. I will add this issue to our list. Please go to the theme panel -> block settings -> inline css and disable the option to minify the css and clear the cache.
Hi Anamaria,
Option to minify the css is meant to help with speed load, right?
Option to delay load foor is also meant to help speed load, right?
According to what you are saying these two options exclude each other.
Makes no sense.
Those options interfere with other options from the plugin for optimization. We will do a fix soon.
