Footer Help
Hi Guys
I’ve noticed that my homepage is showing a different style of footer than the rest of my site. The homepage footer has blue header bar on all the menu subjects.
https://www.tinystepsbabyclub.com/
Image example of homepage footer is here = https://imgur.com/MVwGyNQ
I want my site to have the same footer on all pages (including the mobile theme, which I use) and this is an example of how my footer looks on every page on desktop but not my homepage:
https://www.tinystepsbabyclub.com/join-our-baby-club/
and
https://www.tinystepsbabyclub.com/5-things-to-know-about-sex-during-pregnancy/
Image example of the footer on all other pages that I want on homepage and mobile too is here = https://imgur.com/Fl5GqEG
Can you let me know how I can make my homepage footer the same as the rest of the site (no blue bar) and make sure it is the same across the mobile theme please?
thanks!
TS
Please check the footer option selected in Website Manager when you edit a page with TagDiv Composer. Select the global template for all website pages, then the footer will display the same on whole website.
If you have Mobile Theme, then you can not select the footer you want on posts.
Thanks Bettina
When i open the homepage (which has the wrong type of footer) and go into tagdiv composer and website manager i can only see the global template or no footer options. The post pages (which has the footer i want) doesn’t allow me to use tagdiv composer.
Is there a way i can use the footer that appears on my posts on my homepage and other non post pages?
TS
Try to add this CSS code in Newspaper -> Custom code -> Custom CSS:
.tdc-footer-wrap .td_block_template_5 .td-block-title > * {
padding: 0 !important;
border-width: 0 !important;
Let me know about your results!
Hi Bettina
Unfortunately, that had no effect.
Any other suggestions?
Regards
TS
Please send an email at contact@tagdiv.com and provide wp-admin and Cpanel access so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
