Footer inside container
The footer of my homepage is inside the main container. Have I done something wrong or it’s a bug?
My website: http://wordpress.madonielive.com/
Your footer is empty, if you want to add widgets to it please go to the Widgets section: http://screencast.com/t/4NXpFlXXp Also if you want to hide it please disable it from Theme Panel > Footer: http://screencast.com/t/I9z1w8SO3AQ
This is what happen when I try to disable it:
http://postimg.org/image/sy0369rq3/
And this is what happen even if I fill the footer section with some widget:
http://postimg.org/image/bugtkjffv/
I’ve tried to look into the code and if I add two close div tags before the get_footer() function in the page-homepage-loop.php file, it fixes but I don’t think that this is the best workaround to solve this problem.
Any solutions?
Fixed! A close div tags was missing inside a Ad box widget.
