footer problem
As you can see in this link: https://citycampusdordrecht.com/author/city-campus-dordrecht the footer is somehow a mess. I tried to adjust it: https://citycampusdordrecht.com/contact , but still the last bottom part is not adjustabel as you can see. I do not understand why the footer is not the same on all my pages. Please HELP!
Kind regards
Unfortunately i can not inspect your website because this is set in maintenance mode -> https://i.imgur.com/nvwld6p.jpg
Also the only way that can make the footer from Newsmag to differ in your website is if you have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
The site is not in maintenance mode any more in order to solve this problem…
Could you please check again?
I tried the solutions you mentioned and the problem stays the same.
Kind regards,
Anne
Hello !
We suggest you to install a footer template from the Cloud Library.
Footer can be edited by opening your website manager as you can see here: https://www.screencast.com/t/5VkiUmHQvF Select the footer and scroll to the bottom of your page.
This solved a part of the problem!!
I have selected and adjusted a cloud template for my posts. When I click on ‘view’ the template looks great with the above mentioned way of importing the Cloud footer (https://citycampusdordrecht.com/wp-admin/post.php?post_id=268&td_action=tdc&tdbTemplateType=single&prev_url=%2F%2Fcitycampusdordrecht.com%2Fwp-admin%2Fedit.php%3Fpost_type%3Dtdb_templates)
Only when I make a new post OR change the post template of an existing post, the footer goes crazy again! (https://citycampusdordrecht.com/mini-mba/?preview_id=424&preview_nonce=d66947f19f&preview=true&_thumbnail_id=428)
The same goes for the ‘Category template 7’ (https://citycampusdordrecht.com/category/educations/) (don’t know where to find this one!).
Looking forward to your help!
And it is not only a footer problem… It looks more like a bug!
When I use cloud template 48 Animals Pro, the layout of the post on the screen is not looking good (https://citycampusdordrecht.com/about-city-campus-dordrecht/?preview_id=457&preview_nonce=0505ca3667&preview=true&_thumbnail_id=442)
But when I press on Edit template, the correct layout appears!
(https://citycampusdordrecht.com/wp-admin/post.php?post_id=270&td_action=tdc&tdbLoadDataFromId=457&tdbTemplateType=single&prev_url=%2F%2Fcitycampusdordrecht.com%2Fabout-city-campus-dordrecht%2F%3Fpreview_id%3D457%26preview_nonce%3D0505ca3667%26preview%3Dtrue%26_thumbnail_id%3D442)
So the template is good, but somehow it is not shown the right way in the post.
Really frustrating this!
Kind regards,
Anne
Hello !
– admin url and credentials
– cPanel url and credentials
Please note that due to high number of requests the response time can be delayed up to 48hrs.
