Hello
My footer is like that https://imgur.com/izR2WOC
How can i solve that?
I sent my login info to contact@tagdiv.com
thank you for your help
I think that you are referring that some of information from your footer is not visible -> https://i.imgur.com/0fiQd7k.png this is because that information is set with white and the background color from footer is also white. This can be solve using tagDiv Composer -> http://prntscr.com/v82dgw go to footer select the row and in css tab change the background color -> https://i.imgur.com/sbHJ7R3.png
Hope this will help, if not, please provide me a link to your website!
Let me know the results!
