Footer problem
Footer nice looks at the start: null
But there is an error on the news or some other showing page: null
Please send your site’s URL of the page that has this issue as I need to inspect this in order to provide an accurate solution for this.
Please also try to deactivate all plugins leaving active just the Visual Composer plugin and check again for this.
Please let me know!
My site is http://www.dnevne.net
I am try to deactivate all plugins leaving active just the Visual Composer plugin but the same problem.
I have also tested this and managed to recreate it and seems that is a bug as if other than page builder pages the footer layout uses just one column which generates the issue you have.
We will release an update within this week and we will also include a fix for this.
Thanks for reporting it and sorry for the inconvenience!
  • This reply was modified 11 years by Lucian.
OK. There is another mistake but this can be resolved in CSS.
Like button into Bosnian language, please see the picture:
null
We will investigate that, thanks for reporting it. Could you also please send you site’s URL so I can inspect this?
Like button is not solved?
null
You can fix this by adding this css in your custom css filed in theme panel: http://screencast.com/t/8gxKinceni0Q
.td-classic-facebook {
margin-right: 20px;
It’s a little better but not resolved.
null
I have checked your site and seems to look well now: http://screencast.com/t/Tt04zQgf
Please make sure you empty cache and check again. Increase the margin value if you need more space there and set it to 30px or 40px instead of 20px.
I put 30px but it still does not see the number of facebook likes, I deleted the cache of course.
null
It looks fine on my side as you can see here: http://screencast.com/t/K36mrAGem the css applies as it should.
Please provide a link to a post that has a higher number of fb likes so I can double check this.
Everything looks great when faceook in English.
Set facebook into Croatian, link:
http://dnevne.net/spust-ove-bebe-niz-stepenice-zbog-flasice-mlijeka-ce-vas-nasmijati-do-suza/
I understand please use this css:
.td-post-sharing .td-classic-facebook iframe {
width: 130px !important;
I have also tested this and this css should fix this: http://screencast.com/t/ehX3QSUPTH
Please let me know!
Viewing 14 posts - 1 through 14 (of 14 total)
