Footer Text Problem
Dear, I have not used any link in the footer text. But, when I open the blogging article page, then it shows the link in the footer text. While, there is no link in the footer text in the rest of the website. Please help me to fix this issue.
Look at the pic:
https://ibb.co/kzAPoz
Here is the link of the blogging article:
https://www.pakdefense.com/blog/pakistan-army/
Hello pakdefense,
I did not saw any link to your Footer Text section, as you can see here -> https://www.screencast.com/t/znfTDaLIH
Dear, it seems you have not check the link I have provided in my earlier message. Plz open this link and scroll to the footer text and you will get the link in the footer text.
I have inspected again your footer text but there’s no any link at the Footer text section, as you can see here -> https://www.screencast.com/t/6XzUez0A7C3 Where is the link?
Dear, I do not know why the link is not appearing at your end. Please look at this new pic:
https://ibb.co/ci6u6K
and this:
https://ibb.co/b1DwLe
Also see this as it has defined everything related to my problem:
https://ibb.co/ncMcRK
Hello pakdefense,
Please check this section from here -> https://www.screencast.com/t/W3ggSqNV and tell me if you have any link tag. Make a screen and provide it here. Also, clear all the caches, purge CDN files and check the results. (press CTRL+SHIFT+R)
If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to your setup page.
Dear, I have checked that there is no link in the footer text and I am attaching a screenshot here for further clarification:
https://ibb.co/kT2O0e
Please check this topic: https://paradite.com/2013/12/07/solved-issue-with-vglnk-all-websites-having-a-script-related-to-vglink-attached-to-the-end/
You probably have a chrome plugin/extension causing this. Please test from a different browser
Dear, I have tried using the Firefox browser and Samsung Mobile Browser and the issue is till there.
Dear, You have detected the right track, but my problem lies in the installation of Disqus Commenting system. But, now problem has been solved. Please take a referrence of this link for further possible issues:
https://www.freewebscript.com/knowledge/how-to-fix-viglink-generate-unknown-hyperlink.html
Thanks Again
