footer Where can I edit these parts?
▲The picture is the home editing screen. It can’t be modified.
It’s the bottom part, but this part hasn’t been edited, so there’s still space. It can’t be modified in the home editor.
If I-m right, you are referring to this section https://i.imgur.com/cJ6FNPa.jpg that section is part from the page template -> https://i.imgur.com/s6PvilC.png, when you use the “Page builder + latest articles + pagination” and you can not add more elements, when you can do is to change the number of posts ->https://i.imgur.com/CR72DLi.png to display more posts or reduce the elements from the sidebar widget.
