Please check the screenshot, I can’t see the footer widget, how can I add the footer widget. Please reply to me ASAP. Thanks
Hi Sohaib_Romi,
If you set in footer widget some new elements, those will be display only if that footer section it is empty and is not premade, for example you can use the footer style 2 https://i.imgur.com/ohTyXwI.png there the section 2 and 3 are empty and you can set widgets.
