Footer Widget problem
Hi When loading the footer widget I get the following error codes for clevercookspot.com
ning: array_merge(): Argument #3 is not an array in /home2/raybatch/public_html/wp-includes/widgets.php on line 1160
Warning: array_diff(): Argument #2 is not an array in /home2/raybatch/public_html/wp-includes/widgets.php on line 1161
Warning: Invalid argument supplied for foreach() in /home2/raybatch/public_html/wp-includes/widgets.php on line 1163
Warning: array_merge(): Argument #1 is not an array in /home2/raybatch/public_html/wp-includes/widgets.php on line 1171
Although I have previously added content to the footer now I cannot see it in any of the 3 footer content boxes and so cannot edit. I have not made any changes to the code etc.nullWidget area screenshot
Hello raybatch,
Ensure that you are using the latest version of them installed via FTP way, clear all the caches, purge CDN files and check the results. Also, if you are using some untested plugins, you should remove all of these and check the results. If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page. Provide there the link to this topic so we can quickly identify you.
