Hey,
I have added ads in footer text widgets. They are showing the desktop version of the website but are not working the mobile theme. How do i fix it?
Thanks,
Hello shivamyadav850580,
If you are using the mobile theme plugins, please notice that you will have to add your ad code here -> http://screencast.com/t/6OqnKplt
Thanks for your message!
After the update, mobile theme is not working properly in mobile.
Issues:
No thumbnails (asking to enable thumbnail which is already enabled)
No footer widgets which was earlier
Website logo is disappeared
If I network activate the mobile plugin (plugin not working after that- cant use the website)
Hello all,
Unfortunately, we know about this error caused by our latest update. Please notice that our developers are hard working and we hope to solve this issue as soon as possible. Until we fix it, please deactivate the mobile plugin and the theme will be switched to the general responsiveness mobile version.
Thaks for your understanding and sorry for the inconvenience!
Same issue here for mobile theme, no thumbnails, no mobile ads, no header & footer logo, no javascript working in mobile header.
site is: http://www.expresspakistan.net
waiting for update.
Faryaz.
