Forcing Megamenu to load first
I’ve made changes to the header menu and now my megamenu loads as the final item on the page I want it to load first but that option is now not available anymore on the Header settings in the theme panel, Where can I set this?
I looked at your support documentation but the pages refer to an older version and the Ajax tab is no longer visible in the editor?
Just to be clear on this, I need to have Ajax load the mega menu contents first rather than after the entire page has loaded.Thanks.
I think that you are referring on this option -> https://i.imgur.com/hkBB4BU.png thsi can be selected only if you remove the cloud template and you have the tagDiv Standard Pack plugin enable, unfortunately there is no option on cloud header, sorry.
I note it as a suggestion on our list.
Thanks for the reply.
Was there a reason you disabled the Ajax Tab on the megamenu options in the composer? This would seem to be the simplest solution, just put the tab back to enable this option if you’ve building a new header using the TD composer.
I think our developers forgot about this option. I think it we’ll be add soon for cloud templates.
