Formatting problem
Hi there, i have installed the new newspaper version (6.1) to make some test first.
Here is where 6.1 version is running http://traxsourcemusic.com/juliet-sikora-larrys-garage-ep-kitt093/
and here the version 4.6.2 http://house-language.me/juliet-sikora-larrys-garage-ep-kitt093/
As you can see the version 6.1 is putting a lot of space between lines. All the plugins are disabled. Why is happening that?
And even the font is changed in 6.1 version….
You have an option to change the font from Theme Panel > Theme Fonts: http://screencast.com/t/s5g4dOVT if you use post content as default it will be applied the font that you set for body – http://screencast.com/t/nIwMq2eM8L
I don’t know exactly why you have this issue with space between lines as I have tested this but could not recreate this. Did you copy the content of your article from version 4 to new article on version 6? If you do please change to html editor and copy the content – http://screencast.com/t/vXbDWEQy Also please use pastebin and provide the content from version 4 article so I can test it on my side(change to html editor copy the content and paste it to pastebin).
This code http://pastebin.com/XF0tkZUd works fine on 4 version but i get space on the 6 version
We have changed the css for list in the new version of the theme and because you have this inline css you have this issue with list – http://screencast.com/t/vlfRvcwm You can try this custom to remove that margin – http://screencast.com/t/hJtvYIyM and also reduce line height for post content to the value from version 4 – http://screencast.com/t/HPdOZpk6T so from Theme Fonts > Post Content set it to – http://screencast.com/t/9TbqUdOtb
.td-post-content li {
margin-left: 0px !important;
Hope this helps!
Ok, it seems to work but that space between the image and artist? http://traxsourcemusic.com/juliet-sikora-larrys-garage-ep-kitt093/
Can that be removed via css?
Use this:
.td-post-content center img {
margin-bottom: 5px;
