Forward slashes sow up in every article I post
I thought it was a Total Cache issue, so I restored defaults and deleted the plugin, this was happening before Guttenberg and it just has become such a nuisance. Whenever I start a post, everything looks great in the editor, I don’t see a phantom forward slash in visual or code mode, then I click preview it shows a ‘\’ within the first 3-4 paragraphs at a random line break, no rhyme or reason.
This affects all of the articles on my page, I’m not using many plug-ins aside from Yoast and the default tagdiv stuff.
I walked away a couple of months ago because it really upset me that I spent so much time working on this and couldn’t figure out what happened. Can someone from support please help me diagnose this issue?
If I try to condense the text and get rid of the line break that the ‘\’ appears in the ‘\’ just moves further down the page but never goes away.
Some articles with this problem:
https://consumerclick.me/10-cool-stocking-stuffers-under-10/
https://consumerclick.me/5-free-open-source-apps-for-mac-users/
https://consumerclick.me/top-5-tv-streaming-services/
https://consumerclick.me/what-is-a-vpn/
So that the devs understand I’m not trying to waste time.
I disabled every plugin except for the tagDiv composer plugin and the problem persists.
I even tried with a new post that literally had two lines of text and the slash still appears in preview and published version.
After some investigations, I noticed that symbol comes from your Article Inline Ad section, as you can see here -> https://www.screencast.com/t/cRL0stI3HPsE Please check the code from that section in your theme panel and change it to another valid one, clear all the caches, purge CDN files and check the results.
