https://scrnli.com/4xNwnbaG06lVGj
hi,
Recently i found a critical issue with my website. I do not know how to take further steps against it. Is it normal?
Thanks in advance for your response.
I recommend you to check and clean your files: https://askwpgirl.com/10-steps-remove-malware-wordpress-site/
After that, you should reinstall everything, starting with the WordPress, theme, plugins so that it will be a clean install.
