Front page columns vertical position not lining up
Hi, i have used the newspaper theme (week pro). We are using a three column section on our homepage and i cant get them to line up vertically. I have tried using the standard alignment options and also using css to change margins ect. I’m not a developer so i cant interpret or use code to fix it or see if something is off. Any help would be much appreciated. The two columns under the titles “Veckans krönika” and “Senaste nytt”
https://heat-gaming.se
Regards
Niklas
Hi Niklas, I will recommend to use the layout options from row and columns – https://tagdiv.com/flexibility-rows-columns-newspaper-theme/
Thank you very much Calin, I learned some stuff from page.
I have tried defining both vertical positions for the three columns that are on the same row. I’m starting to believe that it has something to do with the center column. When i change something for that column the other columns move up and down.
Do you have any suggestions on how to get the three columns to be on the same row all lined up vertically. Could it be image size in the center column?
Regards
Niklas
Take a look here in this video for example where are build 6 columns: https://www.screencast.com/t/mZ2c5XamTFN You can play the layout options -> https://tagdiv.com/flexibility-rows-columns-newspaper-theme/ -> https://tagdiv.com/how-to-add-delete-and-duplicate-row-newspaper-theme/
You need to set each column width to 20% for five columns. Also, did you have set the align options on the row or on each column?
